No power
There is no power when the switch is on or off, I checked the battery it is ok all fuses checked there were ok, as well.
  • Posted 30 Aug 2024 10:44
  • By HOSSEIN_NOROOZY
  • joined 30 Aug'24 - 1 message
  • Victoria, Australia
Hossein,
Faulty starter or starter relay. Make sure lift is in neutral. Lift needs to see park brake engaged. Make sure PB switch is working. Possible key switch has failed. Verify power going to solenoid at starter when switch is engaged. Loose cable connections or bad ground can cause this issue. Good Luck.
  • Posted 10 Sep 2024 22:51
  • By Fishmech
  • Virginia, United States
Hangcha FLDCXT160
JLG G12-55A
