No left drive motor operation-contactor will not pull in
Left directional contactors do not pull in. New steer angle pot, swapped contactors, checked for motor shorts. Fault light on proportional steer module flashes 2 times. Left drive motor contactor pulls in on self test, but not on command. Right side functions normal. Anyone have ideas? This is not the EV100- system, it's an SRE Controls system. Thanks
Ser # B35/48 508A 03686
  • Posted 11 Jun 2013 05:20
  • Modified 11 Jun 2013 05:21 by poster
  • By roadtek
  • joined 4 Dec'07 - 123 messages
yep you will need the probit handset
just swapping out the pot on the steer angle wont work... if you change it it also needs to be calibrated which you will need the probit handset and the manual to run it through the calibration routine.
now as far as the self test goes, all that does is test the circuit and if it is pulling the contactor in during self test the circuit from the controller to the contactor is good. It sounds to me like you have another input issue elsewhere.
Get the probit handset and use that to monitor the operation, if there is a fault it will show up and help you locate where the problem is.
  • Posted 15 Aug 2013 23:45
2 flashes means seat switch is open. Sounds like you have a hard fault in the LH controller. Do you have the Pro-Bit handset to clear faults with?
  • Posted 15 Aug 2013 22:28
  • By FarmallFixer
  • joined 16 Jun'11 - 17 messages
  • Kansas, United States
August 1-3, 2025 - Coimbatore, India
September 18, 2025 - Blair Athol, South Australia, Australia
November 04-05, 2025 - Houston, TX, United States
edition #1240 - 24 July 2025
CeMAT Australia 2025 has been underway in Sydney this week, wrapping up today, with the main topics coming out of the event proving to be the very predictable automation and sustainability... Continue reading
Simon Manasseh Simon Manasseh
VP business development for Europe, Noblelift Intelligent Equipment Co
Regional business manager, Doosan Bobcat Material Handling
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
SMV (Konecranes) 4531CC5
Mitsubishi FGE35AT
On the 88th day of the year, 29 March in a non-leap year and March 28th in a leap year, World Piano Day (also known as Piano Day) is celebrated. This date was chosen because a standard piano features 88 keys.
