no hydraulics.
no hydraulics, found pump locked up. as a result of that the pump drive chain broke. checked gears and bearings. all OK. anything special i should know about installing a new chain,front seal,crank seal.? any possible reason for pump lock up. hrs.11,152.
  • Posted 15 Jun 2015 07:11
  • By mechNtraining
  • joined 4 Dec'14 - 35 messages
  • Oklahoma, United States
Do it Today or Tomorrow But You will Do it.
pump locking up not a good thing
first i would pull the filter and cut it open and check for metal, also take the locked up pump apart and see how bad the impeller(s) are, if it is bad you probably have alot of metal in the system too.
if you find any you will be having to flush out lines etc to remove any residual metal in the system.
If you do not do this you will be damaging the new pump when it pulls loose metal into it.
It's a big job to do but is necessary when a pump goes out.
  • Posted 15 Jun 2015 21:42
  • Modified 15 Jun 2015 21:43 by poster
REPOWERTEK Inc
SMV (Konecranes) 4632CC5
UN Forklift FD40T
REPOWERTEK Inc
