No hydraulics
Hello, I'm new to the forum and looking for help on an electric Yale ERC050VGN. This unit sat for about a year with a bad battery. Finally put a battery in it and the hydraulics will not function. The machine will move forward and reverse, just no hydraulics for steering or operating the lift. There are no error codes that I can tell. Sometimes there is a symbol that will come up on the control with what looks like a cylinder and four arrows around it. Any help is much appreciated.
  • Posted 12 Apr 2025 01:47
  • By Jeffrey_Bell
  • joined 12 Apr'25 - 1 message
JLB
Jeffrey,
Sounds like you either have a blown fuse or bad relay. Remove the floorboard and look at the relays at the left side against the frame closest to the battery. The top row of relays left side should be the hydraulic relay. Install new relay or swap with one similar. If the hydraulics still do not work, raise the hood and look toward the back. You should see a small black cover, under will be the fuses. With key switch on, check both sides of the fuses to make sure you have voltage. Do you have the login password for servicing the lift? If not need to call for a tech. If so, press the right arrow key twice, you should see an entry for the password. Once entered the screen will return to the main menu. Press the right arrow key four times until you see a little man. This is the setup menu. Press the enter key to access menu. Scroll down until you see a battery. Press the enter key again and see what the truck voltage is set at. Check the model number, in the middle should have two numbers. This is the voltage of the truck. Make sure they match.
  • Posted 14 Apr 2025 23:37
  • By Fishmech
  • Virginia, United States
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Philadephia, PA, United States
Chandler, United States
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Rail King RK330
SMV (Konecranes) 33-1200C
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
