No fuel coming from EPR
I just replaced the EPR because it was leaking around the housing, once replaced I can't get fuel from the EPR thru the hose, the lock off valve is working and getting plenty of fuel to the EPR, Just not getting fuel to the mixer. Machine will crank and run on starter fluid.
  • Posted 3 Jan 2025 11:53
  • By bruce864
  • joined 1 Mar'16 - 40 messages
Bruce,
Since you had to remove a connector to install, verify all connections are good, clean and tight. Verify fuse 3 has not failed. This supplies power directly to the EPR. Since it starts on fluid, the EPR is no allowing fluid to enter the mixer. If everything checks good, suspect a bad EPR. Swap with a known good operating lift if you have a sister truck. Good Luck.
  • Posted 7 Jan 2025 00:02
  • By Fishmech
  • Virginia, United States
