Linde H35D:
No forward and lowering problem
H35D hydraulic problem. The hydraulics will lift but when lowering you have to raise the idle with the accelerator then it will lower and for travel it will reverse as normal but won't go forward. Connected to Pathfinder current levels are correct for FNR solenoids and joystick control. Tested forward output pressure port and it has none. Swapped FNR control solenoids and it is still the same.
  • Posted 13 Sep 2023 04:56
  • Discussion started by DanielJ
DanielJ
edition #1229 - 8 May 2025
