No drive
Hi - new user here with a troublesome L12. Mechanically trained but I have no knowledge of materials handling equipment.
Purchased used a few months ago for my small business use. All been fine but a few weeks ago the drive would not activate every time. Turning it off and on would reactivate it and it would then carry on fine for a number of uses. Now it is completely stationery but holding down the bump stop on the tiller end does cause it to drive forward. Lift up and down is fine too.
Any suggestions for fault finding would be appreciated. Thank you.
  • Posted 20 May 2018 18:11
  • By happyaslarry
  • joined 20 May'18 - 2 messages
  • Oxfordshire, United Kingdom
Hi all,
I have same trouble also. can any share the workshop document please.
  • Posted 12 Aug 2021 18:25
  • By Syed
  • joined 14 May'15 - 197 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
Many thanks Lindetech
  • Posted 25 May 2018 14:14
  • By happyaslarry
More than likely the potentiometer for the traction has an issue.
May need calibrating or replacing.
  • Posted 21 May 2018 13:13
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
