if green light led in box under seat and in rear ok then can system is ok just incase try pressing the left or right arrow button several times this increases display backlight on display or if it is just display light truck should still function ok
Thanks elektrodrive,that is good advice and It could be
possible for that reason I was write our colegue to check display.I think that must start without display in slow mode.
Hi
Have you considered the possibility of the lcd failing in the display unit? Its known to happen on the efg trucks when water ingress occurs.
HI , i have a new full battery , wiring oke. display give light but no letters on it. the voltage on the control boxes and prints are oke.
the leds on the print in the cabin and in the aluminium box on the top of battery are green so it is oke.
Maybe,but it could be also some bad conection or low voltage,or no voltage on some pin.Did you check battery wiring controllers and is it something strange?Maybe is problem in display,do you try without him to start truck?
Do you have lite on display without letters or is display totaly black?Please write me what did you see
hi ,the serialnumber is 794812401 and year 1998 to 1999. i think there is no data in truck? eeprom empthy or something?
Hello mate
That is hard forklift,you are check fuses and dc-dc converter?Can you give more data from vehicle and to we try together.
