No control in reverse
Drives forward with no issues. In reverse the left motor spins at full speed with no control. Cannot go back to forward without power cycling. Right motor works correctly in both forward and reverse. Traction control module?
  • Posted 21 Apr 2024 05:38
  • By Beek
  • joined 21 Apr'24 - 3 messages
  • Michigan, United States
I replaced the traction control module. Fixed :)
  • Posted 7 Jun 2024 09:26
  • By Beek
Probably, but usually would show an error
  • Posted 4 Jun 2024 05:23
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
1. I have the manual.
2. Brakes release and engage properly
3. forward motion from joystick works properly
4. reverse motion for right drive motor work properly
5. reverse motion for left motor works, but it is at full speed so I automatically turn left in reverse.
6. Once I go in reverse, the left wheel seems stuck in reverse. It will stop when I disengage the joystick but if I try to go forward again the left tire still spins full speed in reverse. Once I power cycle I can again move forward with no issues.
  • Posted 23 Apr 2024 02:46
  • By Beek
https://acrobat.adobe.com/id/urn:aaid:sc:VA6C2:e5aca48c-e085-41b9-b1c7-f293344a9799
Download service manual, I would verify joystick output to reverse first and verify brakes releasing
  • Posted 22 Apr 2024 04:30
  • By Matthew_Reed
GemOne
edition #1281 - 14 May 2026
GemOne
