NISSAN STEERING PROBLEM
Its a CWP02L25S S/N CWP02-9C3262
It will only turn in one direction.
Anyone have some info on this truck
schematic and voltage tests maybe
no codes that i know of
thanks James
  • Posted 8 Jan 2013 04:30
  • By Parkway
  • joined 21 Jan'10 - 83 messages
pkwyls AT verizon DOT net
Sure enough after looking at the chips about 3 times
There was one with the top blown off!
  • Posted 28 Jan 2013 12:17
  • By Parkway
And the problem didnt follow ey? Now you have no steering? Probably a fried print board. With trucks battery disconnected, remove main print board from controller panel and remove metal cover. Look where the gate wires for the igbt's plug in (upper right quadrant of card) and look real carefully with mag glass. Look for blown out component(s). This sometimes happens when the igbt shorts out gate side. Always replace the igbt's with matching pair. Card can be remanned.
  • Posted 27 Jan 2013 11:31
  • By RCAV8TOR
  • Alabama, United States
Installed new igts and currant sensor now getting code
PS-TR. *514 any ideas ??
  • Posted 24 Jan 2013 05:31
  • By Parkway
Swaped the igbts only to get steering code and did not steer ether direction. Going to change igbt's
  • Posted 10 Jan 2013 11:35
  • By Parkway
Parkway; Go to the trucks on board diagnostics and identify what the inputs for the steering are doing and also what the outputs are doing. If the transistor are bad you should be seeing a fault number in the display and you will have lost the traction drive.
  • Posted 9 Jan 2013 02:48
  • By MEngr
  • Missouri, United States
I believe that model has a pressure tansducer on the steering drag link to send a signal to the steering servo. One side of that could be bad as it monitors in a push pull type of manner to adjust direction.
The other possibility and most likely is in the back SCR panel behind the steering board there are 2 transistors on the top right very small in size one is for turning left, the other for right! check the wiring and make sure wires haven't loosened or broken off at the terminal.
When removing the large steering box make sure truck is unplugged whereas if the box touches a contactor bar it will blow it internally and its $1500 bucks. Just let it hang to the side with a block holding it.
This is based of my CSPO1L - CYBO2L
EDIT: A simple test is to swap the transistors if your problem is reversed you know its that transistor.
  • Posted 8 Jan 2013 22:42
  • Modified 8 Jan 2013 22:47 by poster
  • By MarcoMontana
  • joined 8 Jan'13 - 11 messages
check your igbts
  • Posted 8 Jan 2013 11:45
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
Komatsu FD25T17
Manitou M50-4
Muncie, IN, United States
