Nissan forklift P02 - Error code 512 & 530
Hi All,
I have a problem with my Nissan forklift model QP02L25U as following:
This forklift shows the error code 512, 530 when the key switch turns on. After checking this forklift, I find the problem with a traction power transistor.
I replaced a new transistor and the forklift was working normally. But after working for 30 minutes, these error codes appeared again. I have checked and found the problem with the remaining traction power transistor. I decide to replace it with a new one.
After working for 30 minutes, this problem occurs again.
Please give me some advice.
Thanks.
  • Posted 23 Oct 2019 18:34
  • Discussion started by David_nguyen
  • Binh Duong, Vietnam
trung_klc@machinery.com.vn
Hi Elektrodrive,
The battery is good. There is no earth faults.
The max current is 150A when the forklift accelerates.
Yesterday, I replaced two new traction power transistor. But after working 1 hours, one of them was damaged.
What I need to check in this case? Please advise.
Thanks.
  • Posted 25 Oct 2019 13:10
  • Reply by David_nguyen
Have you checked your motor for earth faults? Is their excessive current draw under load? Is the battery holding well under.load?
  • Posted 24 Oct 2019 04:18
  • Reply by elektrodrive
enquiries@elektrodrive.co.uk
edition #1235 - 19 June 2025
JLG 260MRT
JLG 260MRT 2016
Flesherton, Ontario, Canada
Hangcha 78XEN
Hawker Powersource, Inc.
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
