Nissan CWP02L25S Error Code *011
I have a Nissan CWP02L25S ser No 900897 in for repair, when you turn the key switch on the display shows "Traction Trouble *011" the hydraulic functions work and the drive starts to work but as soon as you try to drive at more than very slow creep speed the direction contactor drops out in forward and reverse. its not like a fail safe as the truck doesn't lurch it just drops the contactor out, I suspect either the foot controller or a current sensor. But as I don't do a lot of work on Nissan's any pointers would be appreciated.
Regards Shane
  • Posted 10 Sep 2010 00:39
  • By controlelectric
  • joined 8 Dec'08 - 70 messages
  • Shropshire, United Kingdom
It takes years to build up trust, and only seconds to destroy it. controlelectrics.uk@gmail.com
Hello Shane,
I'm experiencing the same traction control problem with 011 code. 2 forklift mechanics have checked it out and can't find the problem? Where can I find a manual and schematics?
  • Posted 21 Mar 2023 03:25
  • By Albert_Estrada
  • joined 21 Mar'23 - 3 messages
Albert Estrada
Hello Shane,
  • Posted 21 Mar 2023 03:24
  • By Albert_Estrada
Albert Estrada
Hi Ray,
Someone from the forum sent me some fault finding info and it turns out that Code *011 is just to tell the driver that there is a problem, to find the out what the the real problem is you use the display to go though a test routine, when I did the test it came up as a traction fuse fault, which as in your case could have also been the line contactor, these both check out OK on the truck and from the checks I have done it is pointing to a faulty logic.
Shane
  • Posted 16 Sep 2010 04:47
I ran into this problem a few years ago,check line contactor tips for welding or just not making good contact,mine were just barely making contact and the amperage draw was enough to make it drop out and cause this fault.It took me awhile to figure out and you have to fully disassemble the contactor to inspect tips,hope this helps.
  • Posted 16 Sep 2010 02:27
  • By ray_k
  • joined 1 Jul'10 - 39 messages
Enforcer FLBAXT25
UN Forklift FBT20NQZ1
Deborah Baker Deborah Baker
Enforcer FLBAXT25
