Nissan CWGP02L25S 9E0143 - Traction Code 011
Hello,
Key on Traction code 011 Fwd/Rev unit will attempt to move (Creep) then shut down. Ran Diagnostic - T Fuse - Replace fuse - Still not working. Any Ideas or thoughts
prenticelift at gmail dot com
  • Posted 8 Jun 2013 02:05
  • Discussion started by Prentice
Showing items 1 - 15 of 27 results.
Missing B(plus) on one of the small fusses in the back with key switch on==> Acid damaged wires in harness under the battery (different color wire spliced together)
  • Posted 4 Aug 2023 02:32
  • Reply by mike_v
  • Illinois, United States
mike_retired
Hi guys
I'm getting trouble code 11, 515, 530
When the do the self diagnostic test on the dash it's coming up "t-fuse 527" and "open/voltage under 531"
Any advise much appreciated
PD Lift Trucks
Hey y'all,
I'm new on here, I saw you said you Got it.
I'm having trouble with the same kind of forklift.
Nissan 36v electric CWP02L20S.
CODE 011 and 015 we've checked everything and run a self test, and it'll clear the codes, but when I put it in gear forward or reverse, I get the wrench pic and traction 011 code.
PLEASE HELP.
THANKS IN ADVANCE.
  • Posted 21 Mar 2023 02:24
  • Reply by Albert_Estrada
Albert Estrada
Dear Sir,
We have Nissan GQ02 series battery operated forklift. We are facing traction trouble 011 issue and error codes are 515, 530. Checked traction motor, transistors, diodes as per manual and found OK but problem not yet resolved, when we depress accelerator pedal FvR contactor released. Please help us to resolve the issue
This is a transistor control track
  • Posted 5 Jul 2021 11:39
  • Reply by mike_v
mike_retired
  • Posted 5 Jul 2021 11:12
  • Modified 5 Jul 2021 11:13 by poster
  • Reply by mike_v
mike_retired
We are also facing same issue. Did u find the solution for thaat trouble
Same problem we are facing in our forklift. Did u find out the solutin
If my memory serves me right I remember during acceleration there is a second set of clicks when increasing speed like an overdrive. Not on this fork truck but another that is working properly.
  • Posted 9 Apr 2019 04:29
  • Reply by gene_g
  • Wisconsin, United States
Power at fuses
  • Posted 9 Apr 2019 04:14
  • Reply by gene_g
Also forward and reverse contacts will kick out and then reset once you let off the accelerator pedal
  • Posted 9 Apr 2019 04:05
  • Reply by gene_g
B+ is battery power?
  • Posted 9 Apr 2019 03:57
  • Reply by gene_g
Missing B+ on one of the fusses in the back with key switch on. Acid damaged wire in harness under the battery (different color wire spliced together)
Check for B+ voltage all the small fuses
  • Posted 9 Apr 2019 02:54
  • Reply by mike_v
mike_retired
Running into the same problems. Followed trouble shooting tree and checked all fuses. Checked current sensor and swapped controller and associated equipment also. No success. Swapped print board also. No success. Stoned motor and checked brushes and blew out motor. Any thoughts??? Also battery is on floor beside forktruck.
  • Posted 9 Apr 2019 01:31
  • Modified 9 Apr 2019 01:40 by poster
  • Reply by gene_g
  • Posted 26 Jun 2013 00:12
  • Reply by mike_v
mike_retired
Toyota 8FGCU25
Flesherton, Ontario, Canada
UN Forklift FGL25T
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
Nagano NUL120-6
Aichi RX07B
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
