Nisan 1B1 battery is overcharged error
please help with Nissan fb15 1B1 48v.
error indicates that the battery is overcharged.
all settings are correctly installed, the battery voltage is within the norms.
I do not understand what the problem is
ask for any help
  • Posted 29 Jan 2014 20:41
  • Modified 30 Jan 2014 01:21 by poster
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
thank you for your help, sorry for the long answer. were problems with the Internet.
the wires are OK but the problem appears after about 3 minutes
have questions, possible change settings remove the problem?
if so, what kind of.
  • Posted 3 Feb 2014 22:15
  • By alexandr_k
  • Ukraine, Ukraine
I agree with jeremy s.......also you can jumper the two wires and see if code goes away.
  • Posted 30 Jan 2014 14:19
  • By RCAV8TOR
  • Alabama, United States
Check the wires on the bottom of the Emergency Disconnect Contactor if the wires fell off and someone put them on the wrong terminals it can set this code, take the two wires and switch them to the other 2 empty terminals. I have had this problem a couple of times and that has corrected it. Some ED Contactors don't have the two switches at the bottom though. Hopefully that is all it is.
  • Posted 30 Jan 2014 12:56
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Terberg YT223
Enforcer FLBAXT25
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
