Nichiyu (& Nyk) FB20P:
Nichiyu FB20P electric diagram
Dear All,
I have a Nichiyu FB20P forklifts. When start machine, a few of minutes, the error message "A14 sensor-current (amateture)" and " A15 sensor-current(Field)" occur. I have no experience about Forklift. Please give me advise and electric diagram.
Thanks!
  • Posted 18 Oct 2012 14:40
  • Discussion started by jack_t
  • Binh Duong, Vietnam
Jack
Showing items 1 - 15 of 33 results.
Hi guys,
I could really need the schematic and/or the service manual for a Nichiyu FB20P-60C-430M forklift.
The panel says "bypass contact ,chopper travel"
The bypass contactor solenoid is ok (34 ohms) and no welded contacts.
  • Posted 29 Oct 2019 17:31
  • Reply by markusb
  • Sverige, Sweden
You can reach me here, markus.bengtzzon@gmail.com
Good day! Can you help me ? A have forklift FB25P-75-470MFCS
P/N 241AC6908
Dont work turns and panel. Fuses is OK. Can you send me electrical diagrams? [email address removed]
  • Posted 30 Aug 2018 20:55
  • Modified 30 Aug 2018 21:00 by poster
  • Reply by Kerinsky
  • Russia
Ok yes it's an AC model. I guess you have a problem with relais X2 inside the build in charger.
Marcb
  • Posted 10 May 2018 04:03
  • Reply by marcb
  • ANTWERP, Belgium
Thank you for replying. I think serial number is 221AC3846.
  • Posted 10 May 2018 03:06
  • Reply by munkh_s
  • BGD, Mongolia
Hello Munkh, do you know if it's an AC or DC drive motor? If you don't know give me the serial number of the truck. So I believe it's an on board charger?
Regards
Marcb
  • Posted 10 May 2018 03:01
  • Reply by marcb
  • ANTWERP, Belgium
Hello Marc,
I have Nichiyu forklift FB15P-70-300 and it has EPS failure. When I switch key on, steering wheel is very hard to steer. After plug forklift into the charger socket and unplug then switch key on, EPS works fine. Please help me to fix this issue. Thanks
  • Posted 10 May 2018 01:36
  • Reply by munkh_s
  • BGD, Mongolia
could you please help me with the manual for Nichiyu Fb25PN-DG55BC. They said I need to replace the control board and its very expensive?
  • Posted 7 Sep 2016 18:38
  • Reply by justinmurray11
  • Queensland, Australia
Hi guyz, I'm a new mwmber of this furom. Can I ask assistance if someone can find me the complete specs of my Nichui Electric Forklifts?
Model: FB20PN-72C-300WB
S.N# 227 AC 0845
Model: FB15PN-72C-300SF
S.N# 226 AC 0986
Thanks.
johnard
Hope for your positive response.
  • Posted 8 Aug 2016 23:39
  • Reply by johnard_a
  • Davao Del Norte, Philippines
Hey Zul, an error fail voltage travel means that you have a low battery voltage. If you are absolutely shore if it isn't the battery or wiring you have to replace the MPU-Board. An electrical diagram has been send to you.
Regards
Marcb
  • Posted 7 Apr 2016 01:04
  • Reply by marcb
  • ANTWERP, Belgium
Hi All,
I have an issue with our Nichiyu FB25PN-75C-470MSF, S/N : 257C00330 witch currently having problem this faults "Voltage Travel Fault". I already try to troubleshoot but i no clue at all since i do not have any related maintenance manual or drawing.
I need some assistance such as electrical drawing or maintenance manual on how to rectify this problem. Please email me at zulamz79 AT yahoo dot com. Thanks guys.
  • Posted 13 Feb 2016 17:37
  • Reply by Zul_A
  • SELANGOR, Malaysia
Hi Marc
Yes it is 5.5 Triplex Mast
FB20PN-75-550M
Kindly send me Parts manual so that I can select parts.
my contact id
jll DOT engr AT foseco DOT com
  • Posted 17 Nov 2015 20:05
  • Reply by varun_d
  • Maharashtra, India
Hey Varun, is it a 5,5 mtr triplex mast? what is the serial number of the machine?
Regards
Marc b
  • Posted 17 Nov 2015 19:58
  • Reply by marcb
  • ANTWERP, Belgium
Hiii Marc... Thanx for reply...
I have to carry out some work related to Mast. But I don't have part list /numbers
  • Posted 17 Nov 2015 19:11
  • Reply by varun_d
Hello Varum, What part do you or looking for. I need also the part number of the machine.
Kind regards
Marc b
  • Posted 16 Nov 2015 19:48
  • Reply by marcb
  • ANTWERP, Belgium
Hii Marc
I have Nichiyu FB20PN-75-550M. can u help me with parts manual of same.
Plz contact on jll dot engr at foseco dot com
  • Posted 16 Nov 2015 18:03
  • Modified 16 Nov 2015 18:07 by poster
  • Reply by varun_d
Komatsu FD25T17
JLG 600AJ
JLG 600AJ 2012
Flesherton, Ontario, Canada
Toyota 8FGCU25
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
edition #1234 - 12 June 2025
