New U.S. OSHA Crane/Forklift Regulations
The United States Department of Labor, Occupational Safety and Health Administration (OSHA) issued on Monday, August 9, 2010 the final rule for 29 CFR Part 1926, Cranes and Derricks in Construction. These rules take effect 90 days from the publication date. Some forklift operations will be affected by this new rule.
For information and links to this subject matter,
Google: osha.gov/as/opa/cranesderricks-factsheet.html
Powered industrial trucks (forklifts), configured to hoist and lower (by means of a winch or hook) and horizontally move a suspended load fall under the new OSHA Construction Industry Regulations for Cranes and Derricks. Forklift operators will be required to be trained and certified as crane operators under these conditions.
For the final rule and regulations, Google: osha.gov/FedReg_osha_pdf/FED20100809.pdf
"§ 1926.1400 Scope.
(a) This standard applies to power operated equipment, when used in construction, that can hoist, lower and horizontally move a suspended load...
(c) Exclusions. This subpart does not cover:...
(8) Powered industrial trucks (forklifts), except when configured to hoist and lower (by means of a winch or hook) and horizontally move a suspended load."
"§ 1926.1401 Definitions.
Multi-purpose machine means a machine that is designed to be
configured in various ways, at least one of which allows it to hoist (by means of a winch or hook) and horizontally move a suspended load. For example, a machine that can rotate and can be configured with removable forks/tongs (for use as a forklift) or with a winch pack, jib (with a hook at the end) or jib used in conjunction with a winch. When configured with the forks/tongs, it is not covered by this subpart. When configured with a winch pack, jib (with a hook at the end) or jib used in conjunction with a winch, it is covered by this subpart."
Special attention should be given to:
1926.1427 Operator Qualification and Certification
1926.1430 Training
Appendix C to subpart CC of 1926 - Operator Certification; Written Examination; Technical Knowledge Criteria
This standard also applies to construction activities performed by general industry maintenance departments.
Google:
osha.gov/pls/oshaweb/owadisp.show_document?p_table=INTERPRETATIONS&p_id=24789
osha.gov/pls/oshaweb/owadisp.show_document?p_table=INTERPRETATIONS&p_id=21569
  • Posted 16 Oct 2010 08:37
  • Modified 18 Oct 2010 04:31 by poster
  • By joseph_h
  • joined 19 Mar'06 - 253 messages
  • Michigan, United States
Thanks,Please read this article for crane safety
https://stainely.com/20-crane-safety-tips-to-prevent-accidents/
  • Posted 24 Jul 2021 19:05
  • By MrBukhsh
  • joined 24 Jul'21 - 1 message
Khuda bukhsh
Thanks Joseph,
Looks like this will affect machinery movers that use Versa-Lift with a hook or spreader bars.
I know some that have little cranes that quit using them when the new crane cert regs came out a few years ago because their guys weren't CCCO certified.
In California cranes under 5 ton don't need the CCCO operator cert.
  • Posted 20 Oct 2010 01:51
  • By TradeShowDave
  • joined 14 Mar'09 - 48 messages
edition #1276 - 9 April 2026
In this week’s Forkliftaction News , we continue our coverage of LogiMAT 2026 held in Stuttgart with a rundown of some of the biggest product launches at the event which achieved record exhibitor and visitor numbers... Continue reading
SNORKEL A46JE
Unicarriers FD80-2
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
