Need test specs for CAT EP16KT
Model ETB4B00690 The accelerator pedal is what I'm wanting to check out of the truck if possible. there is 4 pins on the pot/switch. Can someone tell me which pins are the pot & switch. and what ohm reading i should be reading. I have a code 51 and also just popped up a code 18. I just got this lift and have no info on it.
Just found this site. My first post!!
  • Posted 21 Jan 2010 09:41
  • Discussion started by Parkway
pkwyls AT verizon DOT net
Thanks, Shane
That would be very help helpful,
I will let you know how it turns out
Thanks again, James
  • Posted 22 Jan 2010 02:17
  • Modified 26 Feb 2010 11:20 by poster
  • Reply by Parkway
Hi James
If you let me know your an email address I will mail you the info you need, if you post it you need to write it as "name at gmail dot com" other wise the site wont allow you to post it or you can add it normally to your profile or your signature.
Regards Shane
  • Posted 21 Jan 2010 18:47
  • Reply by controlelectric
  • Shropshire, United Kingdom
It takes years to build up trust, and only seconds to destroy it. controlelectrics.uk@gmail.com
edition #1229 - 8 May 2025
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
Taylor TX175
New - Sale & Hire
Crown RR5225-30TT321
