Need help on a model G83P-060-SBS-093
Hello, the serial number is P164753, it's an old Yale from the 70's. I'm fixing the brakes, because they are leaking oil or fluid to the brake drums and shoes, and it's not stoping at all. I just ordered a new master pump, shoes, cylinders, but I would really like a service or repair manual of some sort. If its.PDF, paper, faxed, Im willing to buy it. Any help is greatly appreciated!, thanks!! I can post pictures or send them if you need them to help.
  • Posted 11 Jan 2013 02:49
  • By wilfredo_m
  • joined 11 Jan'13 - 1 message
  • Puerto Rico, Puerto Rico
hola estoy necesitado un manual forklift g83p para cambiar los sellos del differencial me podrian ayudar muchas gracias
  • Posted 15 May 2020 11:11
  • By Chris
  • joined 15 May'20 - 2 messages
  • Delaware, United States
would you happen to have the electrical schematic for the g83p or l83p.
  • Posted 21 Oct 2016 01:13
  • By ernest_s
  • joined 21 Oct'16 - 1 message
Te sugiero que revises que el nivel de aceite de tu transmision y tu diferencial para asegurarte que el aceite de la transmision no este pasando hacia el diferencial. Si esto esta ocurriendo, entonces tu problema sera mucho mayor, ya que tendras que cambiar el reten del piñon del diferencial.tengo los manuales de partes y mantenimiento en español. Mi correo esta en mi perfil. saludos.
juan Carlos Pastrana M.
  • Posted 11 Jan 2013 10:55
  • By pastrana_j
  • joined 3 Aug'10 - 103 messages
  • Puebla, Mexico
I have a paper parts manual on your G83- if you e-mail me your fax # I'll send you whatever section you'd like. Don't forget to replace the axle (hub) seals as well.
  • Posted 11 Jan 2013 06:02
  • By bbforks
RAEDER-VOGEL
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Taylor T520S
RAEDER-VOGEL
