Need help finding year of older Clark elect.lift
Hello, I'm new here.I was hoping someone can help me identify my clark forklift so I know what the battery weight should be.All I know is it is an older clark and has #685250 stamped on the rear counterweight. The original battery has been replaced with 3- 8volt and 2-6volt heavy duty batteries.One of the 8 volt blew up. I was hoping just to replace that one with something similar but I can't find anything.Every shop wants to know what the original battery weighs.
  • Posted 15 Nov 2009 10:26
  • By clark
  • joined 15 Nov'09 - 5 messages
  • Alberta, Canada
It is a 1954 model ECE Clark "Clipper" electric truck.
  • Posted 30 Nov 2009 23:24
  • By duodeluxe
  • United States
duodeluxe
wow that model i never seen anyway I'll get you a quote send your email logiclift48 at sympatico dot ca
  • Posted 27 Nov 2009 14:02
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
Okay ,got some numbers.It was on the right side like you guys said.They are hand stamped.
It reads: ECE 78 RM63. The size of the battery compartment is: 25" deep(frt to rear),21" high, and 33" wide. It is 36 volt.
TIA,
Lee
  • Posted 27 Nov 2009 12:05
  • By clark
  • Alberta, Canada
Lee
thanks guys,I looked before,but I'll start sanding that area this week and report back
  • Posted 26 Nov 2009 11:31
  • By clark
  • Alberta, Canada
jim k ,is right! somewhere around the entrance of drivers floorboard between the headguard frame and the battery compartment,sand down the paint.Measure the battery compartment email the size I think i can help you out.
  • Posted 26 Nov 2009 10:04
  • By LOGIC
There should be a model and serial on the right side of frame.What you have install now is not safe.The battery is also the counterweight.
  • Posted 20 Nov 2009 01:13
  • By jim_k
  • joined 28 Aug'08 - 21 messages
