Need emergency help !
Hi there,
changed master cylinder and put new brake pads & wheel
cyl, tried bleeding it, but the brake pedal still go goes to floor won't hold pressure, what can I do ?
mrosupply
  • Posted 20 Aug 2014 04:50
  • By matt_m
  • joined 8 Aug'14 - 7 messages
This is and older posting, did you get and answer, if not have you look at inching valve on the Transmisssion.
  • Posted 2 Dec 2014 03:39
  • By Techhelp
  • joined 16 Apr'10 - 22 messages
  • Wisconsin, United States
If the shoe adjustment doesn't do the trick, Make sure parking brake is off and try bleeding the system backwards with Mighty Vac. (Thus pushing the brake fluid up from the Wheel cylinder to the Master cylinder).
  • Posted 23 Aug 2014 12:32
  • By roadtech
How's the brake shoe adjustment? When I do a brake job I always set the adjustment a little on the tight side so bleeding is easier & the brake shoes will wear in faster.
I adjust the brakes so that- at an idle in gear- wheels off the floor- the drive tires won't turn unless the gas pedal is slightly depressed.
  • Posted 20 Aug 2014 07:34
  • By bbforks
SMV (Konecranes) 4531CC5
Terberg YT223
Terberg YT223
