Motor Speed Sensor
My Yale is moving very slow and the tech that evaluated it said it needs a new encoder bearing. I've looked at the service manual and it doesn't show an encoder bearing in the electric motor. Is that another term for this part on a yale for lift?
  • Posted 19 Apr 2023 00:26
  • By Jerry_Harris
  • joined 19 Apr'23 - 1 message
Jerry Harris
Jerry,
a full model number and serial number would be more helpful.
but like garland said, most lifts "after" a certain year they started putting encoder bearings in the motors, these generally are in the newer AC drive control systems. Depending on your model and serial your machine may or may not have this. Also generally if your display on the dash (if you have one) would be displaying some sort of error code for this when the problem occurs unless it is hardset, then it would show it full time.
But as i mentioned at first, knowing your model and serial would tell us what system you have in the lift. THEN we can go from there.
  • Posted 1 Jun 2023 21:32
  • Modified 1 Jun 2023 21:33 by poster
Jerry,
Most electric motors up to a certain year have encoder bearings which read the direction and speed of the motor. This is replaceable, but the motor will need to be removed to complete. I did not see a serial number which would designate the year. The newer lifts actually have a sensor that is bolted on from the outside. Good Luck
  • Posted 31 May 2023 04:47
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
edition #1264 - 15 January 2026
In this week’s Forkliftaction News , we look at the top five robotics trends forecast for 2026 from the International Federation of Robotics, and it’s an eye-opening read with the potential for robotics, AI and automation to work together to change our sector in fundamental ways... Continue reading
Maxlion ESD15M
Terberg YT220
Australia was the first nation to successfully convert its paper-based currency to polymer banknotes, a technology developed in the same country. The first polymer banknote was a commemorative $10 note issued in 1988 to mark the Bicentenary. The first polymer banknotes were also the first to feature a transparent "window" as a security feature.
Arnold, MO, United States
