Hyster E40HSD2-1:
motor issues ?
I have a E40 HSD S/N A219N03178F. When driving at slow speeds the is a voltage drop and lift hesitates when moving slow forward or reverse. All other functions work fine. Would really appreciate any ideas on this. Thank You
  • Posted 18 Jul 2023 22:20
  • Discussion started by 21stsh
  • Illinois, United States
One thing I forgot to add was when I raise the wheels off the ground I don't have a problem with it dropping voltage.
  • Posted 19 Jul 2023 04:55
  • Reply by 21stsh
Thank you.
  • Posted 18 Jul 2023 23:26
  • Reply by 21stsh
first, make sure the battery has a decent charge on it, if not then charge it and see if anything changes.
second, check all the connections, battery plug, all power cables at the motors and on the contactors.
third, if the machine has mode settings turn it up, if all the way up then turn it down and see if there is any difference.
lastly, you may need to get a tech to check it with the laptop and make sure all the settings are correct in the performance modes and base settings.
  • Posted 18 Jul 2023 23:13
  • Reply by swoop223
edition #1228 - 1 May 2025
Airman ENCL045
Terberg YT182
