Mitsubishi FG35N Low Power
Truck has low power when driving up a container ramp. truck works fine on level ground with and without loads. As soon as it try any incline it loses power. tried changing the main injector and the ECM. Has anyone got any ideas?
  • Posted 24 Nov 2011 01:51
  • By Leon_W
  • Tyne & Wear, United Kingdom
Hi pal,
On top of the injector body there is 2 philips screws holding down a oval shaped plate underneath down the bottom of the shaft is a small gauze disc filter what blocks up and drops the gas pressure,take it out and clean, you can read the gas pressure with uptime if you have excess to it.
Pete
  • Posted 25 Nov 2011 05:45
  • By peter_d
  • joined 4 Jun'09 - 50 messages
  • manchester, United Kingdom
I have also seen this motor run about the way you describe when the "fast tas" (A.K.A. 'Idle air volume learn') was not correctly run after changing a controller or throttle body component.
  • Posted 24 Nov 2011 23:38
yes , it is possible you have a defect lpg injector
  • Posted 24 Nov 2011 16:47
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
there is a primary and assistance injector, and it sounds like you may have the assistance injector disconnected, or maybe it is a bad torque converter?
  • Posted 24 Nov 2011 08:37
This an LPG truck? Might be a loss of pressure from regulator under load...Does this have the Nissan engine with the NIKKI Regulator? If so the Regulator shoud be putting out about 4-5 PSI even unde load,on top of the Regulator is a 17mm hex witha phillips in the middle this is the psi test port put a guage in it and run it into tilt bypass(tilt all the way FWD or Rev) and see if the PSI drops
  • Posted 24 Nov 2011 08:00
  • By kevin_t
Does the engine keep the rotation or goes down significantly?
You might have a problem in transmission or torque converter.
Check the pressure on both,and the aspiration filter.
  • Posted 24 Nov 2011 04:46
  • By feitor
  • joined 6 Jan'11 - 161 messages
  • Leiria, Portugal
my email: rc.feitor@hotmail.com
Muncie, IN, United States
Crown RR5225-30TT321
Kalmar-Ac P100CXD
Deborah Baker Deborah Baker
