Hy guys, i need your help!!!
My Mitsubishi forklift goes slowly accelerator pedal fully pressed.
I controlled accelerator pedal : it's ok.
i controlled battery : ok.
I lifted the traction wheels , pressing the accelerator pedal to have a constant speed, but the speed increases gradually to reach 15km/h.
I have no error code on the dashboard.
If someone have technical book for this forklift!!
MITSUBISHI SERIAL EFB 5A25072
MODEL : FB18KT
YEAR : 2002
Thanks Service T for your post.
i found the problem yesterday, and that is exactly what you told me to control, it was the temperature sensor wiring , It was broken.
Thanks !!!!!!!!
Check the wiring to the drive motors. Brush wear and temp sensor wiring underneath the motors. Make sure you chain your mast!
Thanks for your post , the forklift is a DC model
ac drive motors or is this DC model.
if AC im thinking encoder bearing fault
