Mitsubishi FB15KRT 2005 error code 52 help
Mitsubishi FB15KRT 2005 error code 52 help,
Hello my name is John I am linde mechanic, I wonder if you have the a mitsubishi FB15KRT 2005 error codes, I have a 52 error which I believe that it is related to a failure of lifting, if me pe could help appreciate you it much.
Greetings from Spain
  • Posted 8 Mar 2014 23:54
  • By juanpascual_t
  • joined 10 Aug'12 - 24 messages
  • Spain
Jhon_T
Code 52 pump motor open circuit had it many times most likly brushes or cable on brush gear motor will have to come out as cant check or replace brushes in situ is worth checking current sensor but have never had one go down good luck
  • Posted 10 Mar 2014 04:40
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Check the right hand speed sensor and the circuit back to the logic card. If o, the fault is probably in the logic card. To check you could swap the card into another truck if you have one available.
Correction, misread your post error 52 I described is for an FB16KT not an FB15 model, your fault is the pump motor
  • Posted 9 Mar 2014 22:06
  • Modified 10 Mar 2014 05:21 by poster
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Dallas, TX or Lexington, KY, United States
Tacoma, WA, United States
Orlando area, United States
Highland, IL, United States
Bobcat appoints new UK dealer Liverpool, United Kingdom
Toyota launches three new stackers Columbus, IN, United States
Terberg RT403
Load Lifter LLL6000
Flesherton, Ontario, Canada
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
