mitsubishi fb 16kt
Hi all i have a mitsubshi iam getting a code E ,,no hydraulics anybody got a list of codes for this model ,,sorry no serial nub as i havent seen the truck yet
  • Posted 9 Sep 2011 02:11
  • By DAMO
  • joined 9 Jan'07 - 196 messages
  • DUBLIN, Ireland
Hi , if the accelerator pedal not fully back than the integrated switch on and give a fault E so check the potentiometer under the pedal
  • Posted 10 Sep 2011 00:38
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Thanks for the reply roldann
  • Posted 9 Sep 2011 10:37
  • By DAMO
  • DUBLIN, Ireland
In a cat FB16kt. The code E referes to directional lever beeing in Fw or Rev and/or accel. faulty setting.when key sw. is ON.
Faulty dir.lever, accelerator or logic card.
  • Posted 9 Sep 2011 06:29
  • Modified 9 Sep 2011 06:35 by poster
  • By roldann
  • joined 3 Sep'08 - 86 messages
  • nuevo leon, Mexico
Hi ian nothing came threw
regards damo
  • Posted 9 Sep 2011 03:44
  • By DAMO
  • DUBLIN, Ireland
check your email
  • Posted 9 Sep 2011 03:34
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
Ps i have drive just no hydraulics
  • Posted 9 Sep 2011 03:05
  • By DAMO
  • DUBLIN, Ireland
Thanks for the speedy reply folks i will be at the machine in the morn will keep use posted
Regards damo
  • Posted 9 Sep 2011 03:03
  • By DAMO
  • DUBLIN, Ireland
A solid E is a sro fault normally caused by something jammed under the throttle pedal not letting it fully back to rest. Usually a pen or a stone.
  • Posted 9 Sep 2011 02:46
  • By AndyPandy
Hi Damo
On some of the cat trucks a normal E relates to footpedal error, try pulling the footpedal up towards you. I have had this problem several times on the EP 18KT trucks, perhaps its the same issue.
Regards
  • Posted 9 Sep 2011 02:43
  • By elektrodrive
enquiries@elektrodrive.co.uk
Check if the code is E0, E1, E2, E3, E4,E5 or E6. There are many reasons for E code
  • Posted 9 Sep 2011 02:36
  • By goncalosousa
  • joined 12 Sep'05 - 42 messages
  • Leiria, Portugal
Komatsu FD25T17
SMV (Konecranes) 33-1200C
Linde Material Handling
Kai von Berg Kai von Berg
