mits FG20N ECM
Hi all,
I need to fit a new ecm to a Mits FG20n (2oo6 yom) I don't have the serial number with me at the moment,I have uptime on my laptop, can someone advice me what I have to do, I know that I have to go into the ecm menu and down to the active test tab.
Cheers
  • Posted 1 Jun 2011 04:34
  • By peter_d
  • joined 4 Jun'09 - 50 messages
  • manchester, United Kingdom
Hi edward t,
The truck turns over but has no spark, the battery was flat so the customer tried to jump start the truck probably spiking the unit.
I have tried the ecm on a sister truck and still no spark, I also tried the good unit on the truck and it starter up. How do I go through the learn process step by step if possible.
Cheers
Pete
  • Posted 2 Jun 2011 06:38
  • By peter_d
what is the symptom that makes you think you need an new ecm?
after you change the ecm, you will need to go through the learn processes, including the "fast tas".
  • Posted 1 Jun 2011 20:25
