Did you ever figure it out? We are having the same issue with FWD/REV not working. We got FWD/REV working buy swapping to a REMAN SCR Card but then the other controls quit. so we are keeping the old card. FWD/REV contactors have no voltage on the coils.
Not all EV100 cards are interchangeable.
I believe the MT and LT are twin drive cards, but not sure what the ZM card is. Could it be a ZH?if so, then no.
When I used a card IC3645LXCD1, MT from a three wheel Clark, it doesn't work. There is code 23 show on my handset. Is it possible to program the MT card to fit this 4wheel Mitsubishi?
Ok. Found the IC3645LXCD1, ZM card is bad. Replace another ZM card, everything works.
have you checked the fuses and inputs to the card on the "term strip"?
The card is LC3645LXCD1. Plug LX handset also no display.
Yes. The battery is one year old. Now is fully charged with 38.73v.
Thanks
Truck sat for a month.....how much charge is in the battery is it fully charged and filled to the correct level with water???
