manitou mlt 634-120lsu
hello. having problem with hydraulics on this telehandler. after loading lorrys for about 20 mins hydraulic functions slow down , doesn,t stop though. on the back of the main pump is a solenoid and when you pull the plug from the coil the hyds go back to full speed. does anybody know what this coil is for and what feeds it.
cheers
  • Posted 30 Oct 2009 04:20
  • Discussion started by kevin_k
excellent info BillyB thanks very much. throttle cable is sticking a bit so this maybe upsetting the ECM. thanks again
  • Posted 2 Nov 2009 06:30
  • Reply by kevin_k
This machine has electronic flow regulator - solenoid for hydraulic pump. If there is something wrong with the potentiometer (theoretical rpm) or alternator (actual rpm) the machine goes to the "safety" mode. Or if the cables are broken in short circuit etc.. it goes to safe mode.
If you want to check this you have to have a "Manitou" diagnostic case or Rexroth handheld (only for older electronic - round connector).
If you have to change the potentiomer (it's on the fuel pump) you have to do "teach in" for electronic after you have adjusted it mechanicaly.
Try playing with different positions of this potentiometer or check the alternator if it's working correctly (W cable for rpm). If one of this two signals is different (the electronic compares them with each other by different rpm's) more than 50 rpm (by aprox. 1000 rpm), 150 rpm (by aproximately 1700 rpm) and 250 rpm (by maximum rpm 2.500) the machine goes to safety mode.
Look for broken wires on alternator or potentiometer or bad fuse on the ECM (black box by side where the arm rests when under the plastic cover).
Hope this helps.
  • Posted 2 Nov 2009 06:19
  • Reply by Billy_B
  • Slovenia, Slovenia
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Ncn 110TH
Ncn 110TH 2023
edition #1229 - 8 May 2025
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
