Main lift bouncing a lot
Hi I have a 740 Reach truck, the main lift is bouncing a lot lifting up and down, could this be a bad flow limiter?
  • Posted 11 May 2011 01:44
  • By fredz0003
  • joined 25 Feb'11 - 69 messages
Raymond Action
thanks a lot raytech it was the prop valve out of adjustment.
  • Posted 20 May 2011 05:32
  • By fredz0003
Raymond Action
Hey Fred. In that 7400, with lift up in air, if you hit the lower button all the way real fast and let go, does the carriage lower a bit, or not move at all? If it doesnt respond to quick lift or lower commands, then adjust the Prop valve. (with forks up, disconnect one wire from prop, hold lower button, adjust prop with Allen key until carriage just starts to drop, turn opposite direction until carriage stops dropping, put lock nut and wire back on) Does the carriage respond very snappy now? If not, prop may be shot. Sol 3 could be stuck open too. It is beside Prop valve. Causes lift while reaching, slow lift with heavy loads. Check hyd filter for filings. If any are present, means free lift cyl cushions are in pieces. Do the free lift cyls cushion the last inch ok? If not, better take em apart and put heavy duty ones. There is 2 flow limiters, one in left free lift. other in right main lift. They rarely fail but get clogged with filings.
7400"s will make a tech go grey!
  • Posted 16 May 2011 00:05
  • By EasiTek
July 9-10, 2025 - Birmingham, United Kingdom
Evansville, IN, United States
St. Louis, MO, United States
Daleville, IN, United States
Uxbridge, Canada
UN Forklift FBT18NQZ1
Ncn 85TH
Ncn 85TH 2014
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Hoist Liftruck P360-48
Terberg YT182
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
CEO, MHEDA
