Main Fuel Shutoff problem
Hello Everyone, i'm having an issue with the main shut off solenoid located on the LP regulator. Truck serial numberA875B30777B WITH A ASIAN FUEL SYSTEM epa COMPLIANT. I changed the LP regulator because the truck would not run. After changing the regulator. The Main fuel shut off solenoid clicks at idle and service engine light flashes with the clicking. the clicking is the solenoid shutting off aand on. If i rev up to around 1800 RPM the clicking stops and light goes out and runs fine. I know some have a relay for the main shut off solenoid. not sure where this relay is located and if this truck has a relay. need help please. I replaced
fuel relay shrouded 4 pin. and engine control module still having same issue
  • Posted 17 Sep 2021 00:27
  • Modified 11 Nov 2021 03:15 by poster
  • By Hdsprt
  • joined 12 Nov'15 - 43 messages
  • Illinois, United States
ProMat picks up two awards for 2025 event Los Angeles, CA, United States
edition #1302 - 8 October 2026
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
Libiao Robotics
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Tusk 350CGH20
Taylor T520S
