lpg symbol on dash flashing on and off.1d1/1d2 nissan truck
try to reset and felled.how do you reset it.just come across this on the truck.
i have change from a standard gas bottle to a refillable gas bottle.
  • Posted 20 Mar 2014 05:33
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
If it has a swing out style tank rack then the adjustment of the micro switch on the gate latch should be confirmed. Make sure the switch wiring is ok and wired correctly. If this checks out ok then you will need to check to see if unit has a low fuel pressure switch that s located on left side behind the coolant reservoir. This switch could be going south and needs replaced. If the fuel pressure switch is good along with the wiring, then by all means make sure your refillable tank is delivering liquid lpg instead of vapor.
  • Posted 20 Mar 2014 11:31
  • Modified 20 Mar 2014 11:34 by poster
  • By RCAV8TOR
  • Alabama, United States
SMV (Konecranes) 4632CC5
Tacoma, WA, United States
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
