Lp engine
Continental LP gas engine gains high RPM after it warms up why?
  • Posted 7 Aug 2014 04:20
  • By rex_g
  • joined 7 Aug'14 - 1 message
  • Iowa, United States
Could also be worn bushings in the mixer where the throttle shaft goes through.
  • Posted 7 Aug 2014 22:32
  • By bbforks
check throttle linkage and make sure it is not loose
throttle screw may be turned too far in
air/fuel mixture may be wrong
advance plate in distributor may be hanging up causing it to advance timing and not return to normal timing
many things can cause idle to change and idle up, those are just a couple reasons
  • Posted 7 Aug 2014 20:56
Oxford Ct, United States
