Skyjack SJII3220:
Low power and no high speed travel
My lift recently started having issues. It's has very little power when moving both forwards and backwards and with the platform lowered it will not go into high speed travel/2nd gear, whatever it may be called. The batteries are pretty new so I'm sure that's not the issue. It also worth noting that other functions such as steering, platform raise and platform extension seem 100% with no sign of reduced power. Any ideas would be greatly appreciated.
  • Posted 28 Oct 2022 05:29
  • Discussion started by Steve_Ott
From the parts/service literature from their website
-Work Platform Drives In Slow Speed Only-
probable cause:Remedy:
1. Speed switch (S7-1) defective.
1. Replace switch.
2A. Differential valve coil (2H-18A) or speed valve coils (3H-18A-1, 3H-
18A-2) open or shorted. (Models 3220, 4620 and 4626)
2A. Check continuity. Replace if defective.
2B. Pilot valve coil (3H-18A) open or shorted. (Models 6826 and 6832)
2B. Check continuity. Replace if defective.
3. Dump valve coil (2H-21) open or shorted.
3. Check continuity. Replace if defective.
4. Defective wire #18 in arm cord assembly or loose connection at pin #18 on terminal strip.
4. Check continuity. Replace if defective. Tighten connection.
5. High Speed Limit Switch (LS1) open or shorted.
5. Replace switch.
6. Diode (D17-2) open or shorted.
6. Check continuity. Replace if defective.
7. Defective wire #18, #18A or #21.
7. Check continuity. Replace if defective.
You can go to skyjacks website and to their "manuals" section and download it to help you with location of components etc.
"https://techpub.skyjack.com/en-au/document/?type=manual&id=1463"
If this link does not work then you can go to the website and at the top there will be a menu choice at the top of the right side of the page labeled "MySkyjack" you can find where to go in there.
  • Posted 30 Oct 2022 16:26
  • Reply by swoop223
JLG 260MRT
JLG 260MRT 2016
Flesherton, Ontario, Canada
Crown WP302020
Your Focus
edition #1234 - 12 June 2025
