long crank time, code 42
hi.
i have a doosan g25p-3 ser num kq-01185. seems to crank for a long time and throws code 42. other times it starts fast. changed plugs, wires, cap , rotor. checked coil and pick up coil, seems ok. unless the pick up coil is intermittent. code is for est low..... what is the est?
Any help appreciated.
first time posting just joined today, so far this site is the best.
THANKS!
  • Posted 22 Dec 2017 14:28
  • By forktime
  • joined 22 Dec'17 - 31 messages
  • Alberta, Canada
From what diagrams I have. I don't have a pin e. I also have a -2 schematic. I'm guessing that's not going to work.
  • Posted 23 Dec 2017 01:57
  • By forktime
  • Alberta, Canada
EST means Electronic spark trigger......code 42 is for low coil driver signalmor current......
EST1Low: (Electronic Spark Trigger) is a current driver signal and normally set if the signal from the SECM is shorted to ground.
Check coil driver wiring and connector for shorts SECM PIN 7(EST1) to COIL PIN A
Verify GND on COIL PIN B Verify GND on COIL PIN C Verify GND on COIL PIN D Verify +12vdc on COIL PIN E
To check the Smart Coil internal circuit disconnect the coil connector and measure the resistance from pin to pin
  • Posted 22 Dec 2017 18:41
  • By kevin_t
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 02-8FD25
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
USD1
Toyota 02-8FD25
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
USD1
Toyota 02-8FD25
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
