load centers
As I always explain, forklifts have a capcity and a load center. The LC is measured in inches (mm) and the capcity in pounds (kgs) I explain that the indusrty standard size pallet is 48", and the LC is 1/2 the length of the pallet provided the load on the pallet is even distributed and the pallet is flush against the vertical fork faces. Since the 48" pallet is the industry size pallet, the 24" load center is the industry load center.
Had a session a week or so ago and for 1/2 an hour I am stressing the importance of understanding the 24" LC. We went out into the warehouse, where lo and behold, there was a brand spanking new battery operated forklift to be shipped up north for the gentlemen I was training. As I read the capacity plate, the truck was rated with a 20" load center. Arghhhh!
The only forklfit I have ever come across with a 20" load center, and there goes my credibility. Not quite! The darn machine was from where else? China, and these guys decided to base the truck on a 20" load center. Back to the drawing board having to explain why. How irritating. Why do the Chinese have to be so difficult?
  • Posted 29 Apr 2012 12:23
  • By dan_m
  • joined 14 Oct'05 - 337 messages
Constantly Lifting The Standard!
Dan
The answer is simple, Here is how you work the load centre's out.
A simple method to calculate if a pallet can be picked up is as follows:
The rated capacity of the truck is 1600kg
The Rated Moment is 420mm (this is found by measuring the distance from the centre of the front axle to the face of the heel of the forks with the mast vertical)
The Load centre is 600mm
The size of the pallet is 1400mm x 1600mm
The weight of the pallet is 1470kg
So to work this out
Add: The Rated Moment to the Load Centre
420 + 600 = 1020.
Now multiply this sum by the rated capacity
1020 x 1600 = 1632000 (this is the first part of the sum).
Now add the the Rated Moment to the New Load Centre (this time it is half the shortest side of the pallet).
420 + 700 = 1120.
Now divide this sum into the first part
1120  1632000 = 1457kg (this is the weight the equipment can pick up)
The pallet weighs 1470kg so the answer is NO
  • Posted 12 Aug 2012 02:20
  • By AceT
  • joined 12 Aug'12 - 12 messages
  • Hampshire, United Kingdom
www.acetrainers.co.uk
Forklift & Driver CPC Training Service's
Transport Consulant Service's
Thanks for the heads-up, Ed. If and when I come across one. Locating and understanding the info on their particular forklift is all part of the course, and this Chinese unit, the first I have come across here, threw me. Anyhow, it was just an observation I made last week. They are probably more common where ur at, but not here yet.
  • Posted 30 Apr 2012 22:06
  • By dan_m
Dan, start looking at the data plates of recently built ITA class 2,3 Toyotas, you may find more like this than you expected.
  • Posted 30 Apr 2012 19:55
I remember working on an older Towmotor which , by the model number, led you to believe it was a 3000lb capacity truck. The capacity plate also rated the truck at 3000lbs- but at a 16" load center. I believe it was a marketing ploy to make a 3000lb truck look really small ( the trucks size was extremely small for a 3000lb capacity). It taught me to always inspect the data plate when checking a unit's capacity.
  • Posted 30 Apr 2012 11:31
  • By bbforks
Actually Ed, this was a first in 12 years for me. We don't have exciting lift trucks here. Toyotas, hysters, Clark's and the like, most 5-6k, side shifters, rotating clamp is about exciting as it gets. First Chinese truck I came upon. Had an 80v battery as well which is a first in a forklift around here.
So for us, the 20" LC is a novelty. Very boring place for industrial lift trucks.
  • Posted 29 Apr 2012 23:11
  • By dan_m
Dan, I am pretty sure this is not only this truck, and had you really read carefully the data plates of _all_ the trucks you train on, you may have noticed some other ('large sales number of unit' brand, {whose name I will not mention here, I'll let someone else speak for that brand's fans} brands that have been sold in the USA for decades).
This is not new this year either, it's been a few years.
I think this is a chance to explain 'center of gravity' and how it works with respect to the 'load center' to operators a little further.
  • Posted 29 Apr 2012 22:35
  • Modified 29 Apr 2012 22:39 by poster
In Europe it was the FEM (French Origin) in the 1960s who dictated that all counterbalanced machines be rated at 500mm (20 ins). Larger machines would be rated at 600mm for 5 tonnes and above.
Reach trucks have always been rated at 600 / 610mm because, unlike a counterbalance that can lift everything, a reach truck is designed for pallet work so that is where half the 48 inch pallet rule you refer to works.
Forknlift is absolutely correct in that the adjustment between pounds and kilos makes the adjustment in difference in load centre
  • Posted 29 Apr 2012 22:31
  • By Misterlift
  • joined 2 Jun'11 - 43 messages
  • England, United Kingdom
That is because normally, as most **** and European trucks are rated at 500mm LC which is 19.68" so they have converted it and just rounded it up. Its not just the Chinese. In Europe we rate in KG so a 2500kg machine will be rated @500mm LC but the equivalent US machine would be a 5000lbs a 24" (2267kg at 600 mm LC) So the lost 233kg is due to the 100mm of extra load center.
  • Posted 29 Apr 2012 18:46
  • By forkinlift
  • joined 22 Jan'11 - 57 messages
  • Bucks, United Kingdom
UN Forklift FBRP15NQZ2
Mitsubishi FD200
