linde L10 ppt
Hi,
i have a 2004 Linde L10.
I have an intermittent fault when lifting. Error code 9 flashes.
I have checked all usual stuff, battery condition, contactor tips, wiring condition.
Traction is o.k, fault only occurs when lifting.
This is intermittent so a little harder to find.
Anyone any idea what error 9 is.
Thanks
  • Posted 29 May 2012 05:49
  • By richard_e
  • joined 17 Nov'10 - 30 messages
  • staffs, United Kingdom
Richie
Hi, where can I get the error codes manual?
I have a problem try to change the wire rame that goes from the card to the controls and lost some.
when I turn on the green LED it stays fixed and should be flashing
  • Posted 16 May 2019 03:04
  • By juan_o
  • joined 16 May'19 - 1 message
  • Peru
juan OLivares
Yes you are correct. There are two inline contactors for the pump. The battery voltage stays at 24volts when lift is operated. I will be looking at machine this week. I suspect one of the contactors is faulty. I will post results. Many thanks so far.
  • Posted 8 Jun 2012 23:18
  • By richard_e
For me it looks like 379 series Easy Lift.
The contactors 2K1 and 2K2 contacts are sticked. These contactors are serially connected to hydraulic pump supply line.
  • Posted 31 May 2012 00:43
  • Modified 31 May 2012 01:19 by poster
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
when you say checking battery condition what did you check?
did you do a load drop test while operating the hydraulics?
make sure the voltage is not dropping below the rated voltage of the truck under load.
  • Posted 30 May 2012 20:49
type and sery nr
plase
  • Posted 30 May 2012 02:04
  • By michel_v
  • joined 8 Mar'08 - 1,040 messages
  • noord holland, Netherlands
error 9 is sticking pump contactor look contacts and free moving look connection look motor error is somewhere there.
Good luck
  • Posted 29 May 2012 06:34
  • By nemanja_k
  • serbia, Serbia
Harrisburg, SD, United States
Wentzville, MO, United States
Ottumwa, IA, United States
Terberg YT222
Crown SX3030TT4250
Hangcha CBD15
China
USD1,600
Aichi RX07B
edition #1235 - 19 June 2025
