Linde (& Baker) COMBI TRUCK K SERIES:
Linde K-truck S10735 Rail Guided -Error diagnosis on FE310
Truck was stuck in the working aisle, and display error code 310. Have done the recovery and reset by switching off and on, currently back to normal working condition. The operator instruction show Error diagnosis IN1 to IN13, but it did not stated Fault code, hence need some advise what does FE310 means. I would like to understand whether is this cause by operator error or other causes.
  • Posted 19 Jul 2018 13:36
  • Discussion started by Louis_Tang
  • Singapore, Singapore
What is your issue??
  • Posted 24 Sep 2023 05:36
  • Reply by lifter01
Plz sir i,need your help
IN 1 battery discharged
IN 13 truck not in auto (wire mode) in aisle
FE 310 main lift reference switch switching outside stated range
Remedy if lift encoder cable isn't snapped perform a main lift teach in and check reference switch is working
If your battery is flat it can cause lots of errors
  • Posted 28 Jun 2022 04:10
  • Reply by lifter01
Hi,
Please check serial # k/61x011Z01322/06/2009, i am waiting from your positive response.
  • Posted 26 Jun 2022 21:45
  • Reply by muzffar_h
  • United Arab Emirates
Without the serial number we cannot help please post that
  • Posted 26 Jun 2022 19:11
  • Reply by lifter01
in my k truck error showing 1111 and 1109, 1108. Magnetic switch wiring guidance error. anyone can tell procedure for reset with magnet. correct working module of all 8 nos magnet switches
  • Posted 25 Jun 2022 03:20
I have manage to get error diagnosis of FE310,
Description: - The main lift reference switch trips outside the stated range.
Possible cause: - The main lift reference switch does not trip within the stated range. (Compare with the value from the incremental transducer of the height measurement system)
Remedy: - Reset the error display and the controller by switching the key switch off/on.
- Check the reference switch.
- Check wiring.
- Perform a main lift reference run.
  • Posted 27 Jul 2018 10:18
  • Reply by Louis_Tang
Manitou M50-4
UN Forklift FD35T
Louisville, KY, United States
Dubuque, IA, United States
