Linde Hydostatic Drive
Hi i have a Linde H50D 2009 VW model with 6700 hours.
My quistion is are there someway to refill/bleed the hydrostatic drive from air cause i think its air in the system its making noise when driven,if i go down a hill with full throttle the noise goes away but comes back when it pulls again sounds like a dog thats angry driving me craisy. I can see Linde tells that the hydrostatic drives oil has to be changed evey 6000 hours but dosent tell how.
Els the Display shows a yellow error light that looks like 2 wind/air lines/circles not sure what that means. The truck is operating normally with these faults.
i have ordre the linde 2015 code kit
  • Posted 8 Dec 2015 09:30
  • Modified 8 Dec 2015 09:36 by poster
  • By MichaelH
  • joined 5 Dec'15 - 2 messages
  • DK, Denmark
Wilson, new hoses do not solve noise problem. I have 27 new lindes I take care of and all 27 make this noise. Have changed the hydralic hoses at the hyd tank and it did no good. These are new units and linde will not own up to it. Noise sounds like cavitation. Its not. Noise happens when using hyd functions. Preformance of the units is ok. Its the noise.Linde warranty department stated they would supply 2 new hoses and thats as far as they will go.They will not pay for labor to replace or travel time. Also to, same customer bought 13 new units 2 years ago and after 800 hours noise starts. The 27 new ones stareted soon as we recieved them. Not sure what was changed in the system but linde should own up to it and fix it. The models are H35. LP units. Cant push for customer to buy a linde when linde wont fix what is suppose to be warranty. Clark, Doosan. They stand behind their units.. I love the Linde trucks. But its bad when they wont fix their flaws.
  • Posted 18 Mar 2017 23:53
  • By edward_m
  • joined 11 May'15 - 111 messages
I attend Linde training last month.and Linde have new solution for noisy hydraulic system it will change the new suction pipe you can inquiry the Linde dealer near you
  • Posted 28 Nov 2016 05:10
  • By wilson_b
  • joined 19 Oct'15 - 18 messages
  • RIYADH, Saudi Arabia
I'm TECHNICIAN to save time,Let's just assume I'm always right
One way i have changed hyd oil is take hose off side shift function and fill a bucket.bleeding oil into bucket till cavitation noise starts. I get about 5 gal. then i refill. check all clamps at hyd tank.
  • Posted 9 Oct 2016 13:07
  • By edward_m
Hi, concerning the air in the hydraulics.
Usually, Linde trucks deaerate themselves while working. If the air remains in the system, it means it's getting sucked.
Did you replace the suction filter (in the hydraulics tank)?
If yes, probably you missed to change the big O-ring under the cap.
I've seen it on many trucks, that after the filter replacement, the system suc.s the air under the hydraulics tank cap.
Check the cap itself. It may be damaged. Check the other hydraulics filters.
The oil replacement procedure is described with details in operators instruction. The drain plug is under the truck, on the left side.
You pour the oil through the filler (where the vent filter is).
Concerning the yellow light (does the symbol looks like a spiral or spring?) probably IFD45 was right. It may be glow plug or some engine problerm
  • Posted 25 Dec 2015 04:41
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
Check the hose and clamps prior to the hydraulic pump. It may be pulling in air. I have never had a problem with the air being worked out of the system on a 39x Linde lift after draining oil and replacing filters. It will be worked out when the controls are operated and it is driven.
The yellow flashing light in the dash sounds like the glow plug light. When it flashes there is a fault with the engine controls or faulty wiring.
  • Posted 22 Dec 2015 06:12
  • Modified 22 Dec 2015 06:14 by poster
  • By IFD45
  • joined 28 Feb'13 - 31 messages
  • Wisconsin, United States
IFD45@mail.com
VETTER Industrie GmbH
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Terberg RT403
UN Forklift FD40T
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
