linde h35d codes L233, L223, L237, L239 ???
this stapler is having randomly all those errors, i do not know what those errors means, can anyone help? thank you!
  • Posted 4 Oct 2012 19:35
  • By solmir_v
  • joined 4 Oct'12 - 1 message
  • Germany, Germany
Showing items 1 - 16 of 16 results.
L232 is a lift error not a steer of error and as Michel says is a joystick fault
  • Posted 19 Mar 2021 04:29
  • By lifter01
  • joined 4 Jul'09 - 461 messages
So I figured out the L232 code on the Linde forklift.
There is a sensor on the steering wheel column. I just took it off and cleaned for now. It seems to be working okay.
  • Posted 17 Mar 2021 15:19
  • By Juan_Alba
  • joined 16 Oct'20 - 4 messages
Juan A.
lift joystik cabelbreak ore joystik
  • Posted 16 Mar 2021 04:55
  • By michel_v
  • noord holland, Netherlands
start whit new left joystik
  • Posted 15 Mar 2021 03:58
  • By michel_v
Did you find out what the L232 error code was? I got a similar problem.
  • Posted 14 Mar 2021 09:43
  • By Juan_Alba
Juan A.
good luck
  • Posted 11 Dec 2018 03:09
  • By michel_v
Hi
Good day mr. Micheal i will try the sencsor that u told when i already assemble i hope that will finish the job and tnx in advance sir
  • Posted 10 Dec 2018 21:53
  • By chadaw_isidro
  • joined 12 Sep'18 - 21 messages
  • Saudi Arabia
231 Tilt joystick circuit open
236 Reference signal does not match tilt angle sensor signal
  • Posted 6 Dec 2018 04:51
  • By michel_v
whits truck????????????
  • Posted 6 Dec 2018 04:47
  • By michel_v
232 Steering wheel sensor signal faulty
  • Posted 6 Dec 2018 04:46
  • By michel_v
Hi.
My unit is serial number=C1X335C52296 capacity=2000kg model =E20 P
Year= 2012 pls help im now repairing it hope you can help me with the error code L232
Info about the problem when you key switch on the unit
It will run for almost 3 minutes good condition and suddenly the after a few minutes the unit forklift will be slow running and if u try to key switch off it will stay slow moving wuth error L232 pls help
Also try to replace potentiometer,joy stick left and right still the erro code L232 appearing
SIR THE ERROR IS L232 NOT T232 TNX IN ADVANCE
Pls help me no idea what happen do the unit
  • Posted 3 Dec 2018 18:26
  • By chadaw_isidro
  • Saudi Arabia
Hi,
I see that you have a good experience with Linde forklift, I have a question and I hope you can help me.
I have a Linde 39X H50D, Model 2005, 2 months ago we started to have L231 and L236 error code sometimes during operation when I'm using joystick to tilt the Mast.
When any of these two error codes appears, joystick stop tilting. When I restart the engine, error disappears for 30-60 minutes then it's coming back again during operation.
Now, randomly, errors appears each 5 or 10 minutes.
I tried sprays to improve connectivity, but it didn't worked.
Please some one advise me, should I buy a new Joystick?
And If yes, do I need a software to learn the new joystick to the system?
I appreciate your soonest reply.
Ibrahem
  • Posted 4 Apr 2016 08:29
  • By ibrahem
  • joined 4 Apr'16 - 5 messages
  • Dakahliya, Egypt
hey Mich,
Trying to download the file sent by you...unable to open :(
  • Posted 13 Oct 2014 22:52
  • By pankaj_s
  • joined 12 Mar'14 - 68 messages
  • Maharashtra, India
when you whant i ken sent you een service manual
  • Posted 3 Oct 2014 03:27
  • By michel_v
Thanks!!!!
You saved my day!!! Really aprecciate your help!.
  • Posted 3 Oct 2014 00:06
  • By diego_k
  • joined 22 Mar'13 - 5 messages
  • buenos aires, Argentina
Diego
Hi,
L233, L232 (I understand you misspelled it, there's no L223 error), L237 - they all indicate the problem with additional hydraulics joystick (the further from the seat.)
Replace the joystick (Part No 7919040042 or 41).
L239 is a seat switch.
Check if it works. Check the adjustment (perhaps it is set for too heavy driver). Check the contacts.
Replece if necessary.
If it's random, the error may be caused by the driver.
Good luck
  • Posted 4 Oct 2012 21:23
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
St. Louis, MO, United States
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Ottumwa, IA, United States
Terberg YT222
edition #1243 - 14 August 2025
In this week’s Forkliftaction News , we look at more financial reports with one major producer recording a “significant” decline in Q2 bookings to report an operating loss of USD8.5 million, while another had a strong quarter “despite increased trade tensions and a challenging geopolitical landscape”... Continue reading
Dwight Klappich Dwight Klappich
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Executive director, NT WorkSafe
Chief executive, Logistics UK
