Linde H30 steering
I have a fault with a Linde H30. The steering one way is fine but when you turn it the wheels turn to full lock but the steering wheel wont stop turning on full lock it goes stiff and still turns. When you turn it the good way its stiff for a 1/2 turn then frees up. Have changed the steering valve on the steering colum and it was good for a while then the same fault come back again.
  • Posted 30 May 2010 17:26
  • By Snapman
  • joined 10 Sep'08 - 53 messages
  • Liecester, United Kingdom
You can specify year of construction and machine serial number?
  • Posted 31 May 2010 06:32
  • By andrea_g
  • joined 16 Apr'10 - 15 messages
  • roma, Italy
Your description would suggest that you have found the fault but not the cause, if replacing the orbital valve cured the fault but it came back. I have known the coupling in the tandem pump between the main pump and the steering pump break up sending small pieces of debris into the orbital valve causing all manor of strange symptoms, it may be worth checking this. Also it may be worth resealing the ram as over time the main pressure seal wears in the area of most use, again giving similar symptoms.
  • Posted 30 May 2010 17:48
  • By AndyPandy
Airman ENCL045
Maxlion R2D25
Noblelift
Noblelift
