Linde H25D with Duetz, Transmission stripping issue
Working on a H25D. We have oil leaking from the seal behind the 3 dowled coupling flange on the transmission side, we have removed the engine and now the coupling flange is refusing to budge, we've had a puller on it but still no movement.
Is there anything else holding this in place? I can't see why it would need securing from the inside when a bolt holds it to the shaft.
**** Lindes.
  • Posted 15 Dec 2012 01:02
  • By Fal141
  • joined 25 Mar'09 - 26 messages
Like they said you have to heat it up cherry red and use heayy duty puller. It actually goes on quite easy if you get it super hot. Make sure that once you put the new seal in you put cold wet rags around the shat and housing so you don't melt the new seal.
  • Posted 18 Dec 2012 03:57
  • By duodeluxe
  • United States
duodeluxe
The screw is out, just can't understand why the flange would need to be so tight, it's quite ridiculous. But what do you expect it's a Linde!
Thanks for advise everyone.
  • Posted 18 Dec 2012 00:25
  • By Fal141
As far as I understood you have the problem with the coupling flange P/N 5022307400.
It's mounted on the drive shaft (spline) and tightened with M10x30 heksagon head screw.
Do you have the problems with the screw?
If yes - the Loctite 270 is used there. Try to heat up the bolt.
If the problem is with removal of the flange from the shaft - you must heat it and then use the puller. Sometimes it goes hard.
  • Posted 17 Dec 2012 20:42
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
done a few of these,flange must be heated red hot to remove and refit then douse with water so you dont damage new seal.
  • Posted 15 Dec 2012 20:22
  • By savv
  • joined 15 Dec'12 - 11 messages
  • kent, United Kingdom
From memory it is just a very tight interference fit. If you get it off you will struggle to get it back on again. My advice is to send it to Linde for repair.
  • Posted 15 Dec 2012 02:47
  • By AndyPandy
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
Hangcha CBD15
China
USD1,600
Ncn 85TH
Ncn 85TH 2017
October 8-9, 2025 - Twickenham, United Kingdom
