Linde H12D starts sharp and brake with delay
Hello!
If anyone knows how to solve problem when machine starts sharp with delay and brakes also with delay, please andvice solution.
Thanks in advance.
  • Posted 30 Aug 2012 20:54
  • By edgar_s
  • joined 24 Jan'11 - 6 messages
  • Riga, Latvia
Hello!
Problem is with hidrostatic brake. It has to brake straight away when you take foot from pedal but it brakes with delay. And also there is problem with starting. It starts to move forward only on last few centimeters of pedal move.
Best regards
Edgar
  • Posted 31 Aug 2012 15:56
  • By edgar_s
  • Riga, Latvia
Hi Edgar.
I understand you mean 350-03.
By "brakes with delay" you mean hydrostatic brake or braking with the middle pedal (not presumed for application while driving)?
If it's brake pedal - check the brake valve (under the floor near the front axle)
It it's hydrostatic braking - it may be caused by the leakages on servo, or problems with servo electrovalves.
Such conclusions from the first glance.
Regards
  • Posted 30 Aug 2012 23:51
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
Zhejiang UN Forklift Co., Ltd
Muncie, IN, United States
