the steering motor always running without any operations after key switch ON, Need the information that When steering motor has to start, after steering movement or brake pressing.
one more problem facing in the truck, at the time of movement of th truck if we press & depress the accelerator pedal 2 to 3 times, all the traction function will stop, then we need to switch off the truck & again switch ON,
I have wasted last three days in this problem, Your inputs will be really helpful, thanks in advance.
Your accelerator pot neutral is probably to far from the last calibration date stored in the controller. When it happens, look in the windows2 of truck doctor for actual fault code and then address your issue from there. Also go in the calibration windows for the accelerator and look at the stored data and compare it with your actual value. If too far then calibrate it. If you cannot then replace the two pot gears that connect the pot to the pedal. If all good you might wanna look at then motor condition and the battery.
what code is there on field 2 when the truck is in error??
whits foudcode ??????........ Means fault code...
There is no fault code for this problem..
Contacts means contactor.. or what..
Yes we have linde computer.
hef furst one look on conakts
one more problem facing in the truck, at the time of movement of the truck if we press & depress the accelerator pedal 2 to 3 times, all the traction function will stop, then we need to switch off the truck & again switch ON,
Can u suggest What i can do, need to replace the Traction potentiometer or any other, Please sugge
