LINDE E30S G1X336R50070 SHUT DOWN!!!
The forklift were running perfectly and suddenly shutted off.
Battery is good,checked cables and connections seems ok.
When turn key on,only the strobe and front lights work,anything else!!!
All your help would be much appreciated,thanks
  • Posted 5 Jul 2011 00:50
  • By feitor
  • joined 6 Jan'11 - 161 messages
  • Leiria, Portugal
my email: rc.feitor@hotmail.com
look to you mail
  • Posted 9 Jul 2011 15:13
  • By michel_v
  • noord holland, Netherlands
Model : E30/600-03
Year :2004
  • Posted 9 Jul 2011 06:15
  • By feitor
  • Leiria, Portugal
336 -1 or -2 -3???????????
  • Posted 9 Jul 2011 03:11
  • By michel_v
Changed the transformer for a new one,nothing!!Changed the K2 relay(inside diode was burned) and now the display and the line contactor are working,but no traction,no steering and no hidraulics!! No codes shown in diagnosis tool!!
Changed the logic card LDC-50/10 CE03 and only the backup alarm works, still nothing else!!!
  • Posted 9 Jul 2011 01:31
  • By feitor
  • Leiria, Portugal
try new one
  • Posted 8 Jul 2011 21:31
  • By michel_v
I checked the emergency switch but no micro inside,its a simple switch with only a cable from the battery connection,and on the other side goes directly to the fuses(F1 and F2).
I think the transformer might have "burned" something when he damaged.
  • Posted 8 Jul 2011 18:53
  • By feitor
  • Leiria, Portugal
look for emergency stop switch er are one smal micro swicht in it
  • Posted 7 Jul 2011 04:46
  • By michel_v
Thanks for your attention.
I´ve switched the transformer (input 85v but output only 3,5v)from another forklift and output was ok(24v),but the problem still is the same. What could be damaged after that?Any ideas?
Thank you very much for your help,best regards.
  • Posted 6 Jul 2011 20:24
  • By feitor
  • Leiria, Portugal
hef one look for transformer part nr 7917401264
  • Posted 6 Jul 2011 17:30
  • By michel_v
pls check the master switch
  • Posted 6 Jul 2011 00:49
  • By joel_zhou
  • joined 5 Mar'09 - 31 messages
  • singapore, Singapore
