Linde (& Baker) 394:
Linde 394 auto engine shutdown
Is it possible to activate the auto engine shut down through pathfinder?
The option is there and I've activated it but nothing happens.
Is there something I'm missing?
Thanks
  • Posted 23 Mar 2022 02:48
  • Discussion started by andrew_k
  • England, United Kingdom
Basically what the customer wants is to save money on fuel, the truck already has a Curtis keycode pad fitted which if wired up correctly should time out after 3 minutes. Is there an easy place to pick up the seat switch signal where I could connect the keypad wire which would time out the engine once it sees the seat switch signal change?
  • Posted 25 Mar 2022 03:40
  • Reply by andrew_k
There is an additional harness required that runs from under the floor plate back to the fuse box and then a tail lead that plugs into x10 plug if I remember correctly
Then turn on the function and set time for shut down and u will be all good
  • Posted 24 Mar 2022 20:36
  • Reply by Lindetechnz
  • New Zealand
Lindetechnz
I think I still need a piece of wiring harness
  • Posted 24 Mar 2022 07:11
  • Reply by michel_v
  • noord holland, Netherlands
H2X394U04293
2005 if i remember rightly??
  • Posted 24 Mar 2022 06:19
  • Reply by andrew_k
whits jaer of bild
  • Posted 24 Mar 2022 06:10
  • Reply by michel_v
Hello, Yes seat switch working correctly. I have 2 trucks and I cannot get either to shut down.
  • Posted 24 Mar 2022 05:29
  • Reply by andrew_k
is your seat switch working properly
  • Posted 23 Mar 2022 19:25
  • Reply by michel_v
SMV (Konecranes) 16-1200C
TCM FHD105Z
Your Focus
Jefferson, WI, United States
Johnston, IA, United States
St. Louis, MO, United States
