linde 393 error 236
hello we have a linde 393 h35t from2008 and it shows error 236 wich is Incompatibility between signal/reference potentiometer tilting. we changed the tilt angel sensor, after that we calibrate the tilt sensor, but it still making the error 236 , 8-10 times in a working shift.
what else could it be?
  • Posted 31 Mar 2016 01:38
  • Discussion started by daniel_a
  • ARGES, Romania
The problem is not in joysticks probably you have to give some tolerance while you celebrate the tilt angel because if you will put zero tolerance the mass is so long thats why it is not come on same position give some tolerance 5 and you will not have this problem again
Mnish
Change the joystick, and recalibrate the system.
Mirko
  • Posted 31 Mar 2016 21:10
  • Reply by mirko_c
  • Reggio Emilia, Italy
L236 is joystik ploblem
  • Posted 31 Mar 2016 07:05
  • Reply by michel_v
  • noord holland, Netherlands
Have you tried calibrating or even replacing the joystick?
  • Posted 31 Mar 2016 06:45
  • Reply by little_forker
is the linkage all ok that holds the sensor
  • Posted 31 Mar 2016 05:00
  • Reply by kevin_k
UN Forklift FD50T-NJB3
Komatsu FD25T17
