lift shakes during plugging
This unit will shake the platform when on wire guidance, driving forks first, when I plug to go power unit first. This is the only time this happens. It doesntgo off wire. You can hear the drive unit pivoting back and forth when this occurs. after tryi g to calibrate it, ive changed the ecr2, both sensor bars, access 6, access5. Im think it might be mechanical at this point.
  • Posted 7 Sep 2013 01:56
  • By crownfresno
  • joined 7 Sep'13 - 2 messages
I know this is an old message; that being said, I have found that a bad thrust bearing in the drive assembly will cause similar behavior.
  • Posted 27 Dec 2017 23:49
  • By margaret_w
  • joined 27 Dec'17 - 8 messages
  • Arizona, United States
If drive wheel or load, are faulty, the closed loop circuit, will try to correct this, with wire guidance, the floor and truck wheels are usually the first place to look, you have 4 pick up sensors, 2 in the power unit, 2 forks first side.
  • Posted 9 Sep 2013 18:46
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
Komatsu FD25T17
Crown CG33P5
Komatsu FD25T17
Crown CG33P5
