lift mast
newbe to the forum i have c500 im losing lift power sounds like fluid from the lift cly. its a 2 stage mast tilt cly work ok also have a puddle of hyd. fluid under left front wheel that maybe another problem thanks for any help
  • Posted 31 Aug 2016 10:49
  • By stansab
  • joined 2 Jan'13 - 5 messages
  • Ma, -
Showing items 1 - 20 of 26 results.
ok...im always working with others that also are mechanics but not in forklifts.. different animal...all are chained up..thanks for the warning...So this yoke support adapter is at the complete bottom..right..i am replaceing the next seal up from bottom but need to raise piston up out of bottom where i see those lock keys to hold piston in..Then i think a can remove seals and replace using like u said a sharp screw..just making sure we r talking same area. there is also a piston craddle on this second stag seal im replacing..will i have to remove the bottom fluid control up under craddle that have the 4...1/4 " bolts?
  • Posted 15 Apr 2017 23:43
  • By abuzzon
  • joined 3 Apr'17 - 13 messages
  • New Jersey, United States
You have to lift that yoke support adapter up and remove the snap ring on the underside so it will drop off. Please be very careful working on that, it isn't easy to replace the seals. There is going to be a brass adapter in where the seal is. That comes out first then there is the seal. I found a good way to get the seal out is to use a long sharp wood screw and screw it into the seal then pull it out. I'm warning you this is not going to be easy and can be very dangerous. Someone should help so you have extra hands.
  • Posted 15 Apr 2017 05:09
Hi mrfixit and Brewski.. I have just completed all but one problem.. second stage on bottom of mast is leaking.. looks like in packing....there are three lock rings at bottom of piston (like on top) but need to release them to just slip new seals on the stage above it.. ive got a 20 second video and a couple of picks to show u my debocle.. if maybe one of u guys would reply with ur email so i could show u or if u understand where im at, a reply would also be great..Happy Easter and thanks for all the help up to now..:).Im [email address removed]
  • Posted 15 Apr 2017 01:55
  • By abuzzon
Ok since my Clark fork lift has LPG... that is possibly an abandonfuel tank.. guess I'll pump all the hydraulic fluid out of left side and put in right side.. where is fluid for steering?
  • Posted 11 Apr 2017 07:43
  • By abuzzon
Right side hydraulic tank, left side gasoline
  • Posted 11 Apr 2017 06:20
Ok now sitting in forklift which side is hydraulic.. both sides pretty empty and don't know which side does what.. larger cap female type pipe thread on left and a 5/8 male steel plug on right.. dave
  • Posted 11 Apr 2017 05:12
  • By abuzzon
Sounds great.. now I've got two tanks (resouviors) on each side. Sitting in vehicle a 5/8 male plug and on right is a larger metal female cap on left...what fills what as both seem empty or close to it.. one I'm thinking is hydraulic and on possibly steering and what types should I use..Dave
  • Posted 10 Apr 2017 04:55
  • By abuzzon
Hold the lift lever up and wait, oil will start to fill the cylinder, it takes 5-10 seconds. Then there is a bleeder plug right on top of the cylinder, facing down. Be careful and make sure the forks are down when you remove bleeder and watch out for a oil geyser when all the air finally comes out.
  • Posted 10 Apr 2017 01:11
Ok.. removed and replaced gasket on fluid control valve under main mast.. not to bad but now since it seems most of the hydraulic fluid has drained from main mast and line was disconnected from valve control, so I've got a complete hydraulic system airbound.. I ran forklift about 20 min but only tilt works which I never touched..I worked the control up and down but there must be hopefully a trick to bleed all this air.. anybody got any suggestions.. thanks Dave
  • Posted 10 Apr 2017 00:38
  • By abuzzon
Anybody know what this brass block does with the black hand screw cap?
  • Posted 8 Apr 2017 06:50
  • By abuzzon
One more question.. what is the square block attachehed to this fluid controller which has a plastic-black cap which by hand unscrews?
  • Posted 6 Apr 2017 02:27
  • By abuzzon
I have replaced a lot of tem through the years.
  • Posted 5 Apr 2017 22:16
  • By BREWSKI
Ok that answers that..going to remove this weekend , bottom flow control with the four bolts and hopefully replace the seals.. that seems likely where the leak is as cylinder above cradle does not appear to be leaking.. is this flow control usually a problem with these cylinders? Again thanks for all ur input.. Dave
  • Posted 5 Apr 2017 09:49
  • By abuzzon
The two bolts hold the lower yolk in the cylinder cradle. You can remove the flow control without removing the two side bolt. Removing the side bolts will allow you to remove the cylinder from the mast.
  • Posted 5 Apr 2017 06:48
  • By BREWSKI
Ok thanks.. what do these bolts do that just turn? I will look for those nuts but do these bolts have to come out to drop out bottom fluid vessel with 4 bolts?.. thanks both of u for any info u guys can share.. dave
  • Posted 5 Apr 2017 05:51
  • By abuzzon
You must have dirt. There are nuts in there that you have to hold on to.
  • Posted 5 Apr 2017 04:10
Yea the two 3/8 bolts seem to just spin but don't tread out??
  • Posted 5 Apr 2017 03:25
  • By abuzzon
You need to remove the four 1/4" 12 point head bolts that hold that square aluminum valve on the bottom. Then the two 3/8" bolts that keep the round "foot" thing in place.
  • Posted 5 Apr 2017 02:34
You will need to contact your local Clark dealer for a manual. They may copy the exploded view out of the parts manual.
  • Posted 4 Apr 2017 22:50
  • By BREWSKI
Wow.. yes finally got someone that knows this forklift.yes the bottom shelf cylinder holder appears to leak..the bottom of piston has a packing sleeve that looks like and does unscrew with a tap of screwdriver and hammer.. does that need to be released also or do I just unbolt bottom fluid vessel.. re :4 bolts? Fluid appeared to be coming up through this sleeve..is there any manual that u could suggest to buy to give me an exploded view of piston. The manual I have only shows a single stage piston.. would really like to educate myself on this multi stage piston.. any more help would be greatly appreciated..Dave
  • Posted 4 Apr 2017 10:34
  • By abuzzon
Maxlion R2B25LI
Autolift E180AT36B-D5-180
Noblelift
Maxlion R2B25LI
Maxlion R2B25LI
