Leaking tanks.
Thanks for all your help with the previous problems. Have a new one. Within the past 3 weeks or so, I've had 2 trucks come in with the hydraulic tanks leaking from behind the bottom mounting strap. We're a cold-storage operation in a VERY old building (cracks, potholes, etc.). My question is are we unique in this problem?
  • Posted 26 Aug 2009 09:48
  • By jeff_i
  • joined 2 Nov'08 - 15 messages
  • Iowa, United States
What mil is the sheeting? Might try it.
  • Posted 29 Aug 2009 07:51
  • By jeff_i
We put the sheet against the bulhead behind the tank, as well as grommets at the studs.
  • Posted 28 Aug 2009 12:45
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Did you put the sheeting behind the tank, like a gasket? Would rubber grommets on the mounting studs do the same thing?
  • Posted 28 Aug 2009 07:54
  • By jeff_i
We had to do ourselves.. just absorbs a little vibration
  • Posted 27 Aug 2009 09:56
  • By JonG
  • United States
All they say is when the new tank will be here. Just glad to get the $600+ for the new tank. Is the rubber sheeting a factory option or something you contract out yourself?
  • Posted 27 Aug 2009 08:39
  • By jeff_i
No, I have seen leaks before.. what does the dealer say?
We fixed it with new tanks, with rubber sheeting installed.
  • Posted 27 Aug 2009 01:39
  • By JonG
  • United States
